NSU 250 max spezial 1955: restauration.
+26
Chris
Diabo
luckyck
Willy31
Zündappmann
ours57
JR
BernardP
patj
yannick pompidou
barbe en zinc
piegux
Fr@nck03
L'arverne
Jagbruno
Henri
Lolo49
30 participants
Page 5 sur 7
Page 5 sur 7 • 1, 2, 3, 4, 5, 6, 7
Re: NSU 250 max spezial 1955: restauration.
Assembling the two eccentric discs
The NSU Ultramax system
A distance rod B drive rods
C counterweight D distance ring
E bronze sleeve - connecting piece
Left the camshaft with the rockers.
Explanation
The parts in the animation are made transparent, so the movements can be seen.The blue drive rod rotates at the front (right side of the engine).
View: at the camshaft drive system from the right.
The lower drive is the crankshaft drive sprocket z = 22.
This sprocket drives the lower eccentric drive wheel z = 44.
The lower eccentric discs are attached to the lower eccentric drive wheel.
Lower part - crankshaft
The crankshaft rotates clockwise and the blue square is the keyway in the crankshaft (and for the coupling and Dynastart), which also indicates the position of TDC (OT) of the pistons. The lower eccentric drive wheel runs at half speed counterclockwise. The speed of the lower eccentric drive wheel is indicated by a black dot. Two identical eccentric discs are mounted in a fixed position among the drive wheel. The disc combination revolves eccentric around the 12 mm pin (yellow cross with white dot).
Upper camshaft system
At the top is a eccentric discs combination that makes the same circular motion. Camshaft-bearing is drawn as a thick black circle, which in reality is behind the 2 drive rods running. A counterweight causes the eccentric system well in balance thereby preventing engine vibration.
Fixed drawing next to the animation above
In this position the pistons are at top dead center (TDC) or in German: the Oberer Totpunkt (OT) and cylinder 2 is to ignite. The upper camshaft drive system (thick circle and arrow direction) drives the camshaft through a bronze connecting piece or sleeve (orange) and a drive pin (red), so the camshaft is rotating.
Reliable camshaft drive
MotorcyclesThis Ultramax camshaft drive system was first applied to the motorcycles of NSU, the NSU Max NSU Max 300, NSU Supermax, SuperFox NSU, NSU Maxi, NSU Sportmax, Geländemax NSU and NSU Maxima scooter 175 cc (1960).
From 1952 to 1963, approximately 160,000 copies made.
Cars
From 1958 the first cars, the NSU Prinz I to III, was equipped with this camshaft drive system. From 1959 the NSU Sport Prinz 1961 and the NSU Prinz 4, produced till 1973: a total of 740,000 cars.
A total of approximately 900,000 engines were made with this unique NSU Ultramax system.
Prinz 4 Cylinder Overhaul
For dismantling and assembling the NSU Ultramax system see the page
cylinder head overhaul Prinz 4...
traduction google
Explication
Les parties de l'animation sont transparentes pour que les mouvements soient visibles.
La tige d'entraînement bleue tourne à l'avant (côté droit du moteur).
Vue: au niveau du système d'entraînement de l'arbre à cames de la droite.
L'entraînement inférieur est le pignon d'entraînement du vilebrequin z = 22.
Ce pignon entraîne la roue motrice excentrique inférieure z = 44.
Les disques excentriques inférieurs sont fixés à la roue motrice excentrique inférieure.
Partie inférieure - vilebrequin
Le vilebrequin tourne dans le sens des aiguilles d'une montre et le carré bleu est la rainure de clavette dans le vilebrequin (et pour l'accouplement et le Dynastart), qui indique également la position du TDC (OT) des pistons. La roue motrice excentrique inférieure tourne à mi-vitesse dans le sens anti-horaire. La vitesse de la roue motrice excentrique inférieure est indiquée par un point noir. Deux disques excentriques identiques sont montés dans une position fixe parmi la roue motrice. La combinaison de disques est excentrée autour de la goupille de 12 mm (croix jaune avec un point blanc).
Système d'arbre à cames supérieur
Au sommet se trouve une combinaison de disques excentriques qui effectue le même mouvement circulaire. Le roulement de l'arbre à cames est dessiné comme un cercle noir épais, qui est en réalité derrière les 2 tiges d'entraînement en cours d'exécution. Un contrepoids provoque un bon équilibre du système excentrique, empêchant ainsi les vibrations du moteur.
Correction du dessin à côté de l'animation ci-dessus
Dans cette position, les pistons se trouvent au point mort haut (TDC) ou en allemand: l'Oberer Totpunkt (OT) et le cylindre 2 doivent s'enflammer. Le système d'entraînement supérieur de l'arbre à cames (cercle épais et sens de la flèche) entraîne l'arbre à cames à travers une pièce ou un manchon de raccordement en bronze (orange) et une broche d'entraînement (rouge), de sorte que l'arbre à cames tourne.
Entraînement fiable de l'arbre à cames
motocyclettes
Ce système d’entraînement d’arbre à cames Ultramax a été appliqué pour la première fois aux motos de NSU, NSU Max NSU Max 300, NSU Supermax, SuperFox NSU, NSU Maxi, NSU Sportmax, Geländemax NSU et NSU Maxima scooter 175 cc (1960).
De 1952 à 1963, environ 160 000 exemplaires ont été réalisés.
Des voitures
À partir de 1958, les premières voitures, les NSU Prinz I à III, sont équipées de ce système d'entraînement par arbre à cames. À partir de 1959, la NSU Sport Prinz 1961 et la NSU Prinz 4, produites jusqu'en 1973, totalisaient 740 000 voitures.
Environ 900 000 moteurs ont été fabriqués avec ce système NSU Ultramax unique.
http://www.nsu4.nl/english/e1ultramaxcamshaftsystem.html
motocyclettes
Des voitures
http://www.nsu4.nl/english/e2cylinderheadremove.html
:bien:Merci pour les explications, j'connaissais pas
ours57
NSU Max
Jpd, je vois que tu as refait l'amortisseur arrière de ta Max. Je suis en train de refaire ceux de l'avant sur la mienne. Apparemment, ils sont assez semblable à celui de l'arrière. Tu n'as pas eu de souci pour remonter les petites pièces (coupelle, ressort et petite pièce biseautée, en haut à gauche sur la photo) qui vont au fond de l'amortisseur ? Et quelle huile utilises-tu ? Merci de ta réponse.
JR
Cela ressemble fortement.
Je n'ai pas eu de problèmes au remontage.
J'ai mis de la motul 10 w huile de fourche,remplir au maxi.
J'avais acheté le kit de réfection.
J'ai aussi acheté le kit de restauration. Je vais m'appliquer pour que les petites pièces ne se barrent pas dans le tube au moment du remontage.
Merci pour le conseil sur l'huile.
JR
petit tuto du démontage du moteur:
https://www.youtube.com/watch?v=K4qAZkVPDds
Merci ! Mais j'espère ne pas avoir à démonter mon moteur ...
JR
Bon courage ! Le mien a toujours tourné comme une horloge, alors je n'y touche pas ...
JR
Merci!JR a écrit:Bon courage, et bonne année 2022 !
Bonne santé !
patj a écrit:c'est pas le cadre qui va te gêner ahah
C'est sur !
Très particulier !
Mais avec un bon outillage et le manuel d'atelier NSU en français, ça se démonte pas trop difficilement.
Si quelqu'un a une hypothèse sur la casse du segment...
Question sur le sens de montage des segments .
Je reprend le remontage de mon moteur et j'ai une question sur le sens et le remontage des segments.
Je n'ai pas eu d'indication de mon fournisseur allemand et pas d'indication sur les segments .
J'ai fait un petit schéma avec la forme de mes segments et leur position :
A votre avis ,c'est bon ?
Les réponses à ma question :
https://bienvenueauflatistan.motards.net/t53120-question-sur-le-sens-de-montage-des-segments
Après de multiples vérifications, c'est bien le bon montage .
Peu de commentaires, mais je pense qu'on est plusieurs à suivre ta démarche avec intérêt.
Merci.
J'ai remonté le moteur dans le cadre avec un peu d'aide parce qu'il pèse plus de 70 kg.
Il ne me reste plus qu'a remonter le réservoir d'huile et tester la bonne circulation d'huile dans le moteur.
Je pense la faire retourner sur la route fin du mois prochain...
» R50 1955 restauration...
» Restauration d'une R67/3 attelée
» Pneu neuf Metzeler touring spezial 4x18
» [R50] restomojo
» r50 de 1955
» [R50] restomojo
» r50 de 1955
Page 5 sur 7
