conecteur voyants R80GS
Comment savoir quel fil correspond à quoi sur la fiche qui se connecte sur la plaque support des voyants d'une R80GS?
Je n'ai pas trouvé de schéma ni de sujet s'y rapportant dans le forum.
tak
Re: conecteur voyants R80GS
Ou ça peut-être ?
N° 3 sur le plan et 14 au dessus
1. Front right indicator
2. Headlight box
3. Control lights connection
4. Front light
a. High beam
b. Low beam
c. Parking light
5. Instrument light
6. Connection for tachometer (optional)
7. Key switch
8. Front left indicator
9. Connection
10. Connection
11. Horn switch
12. Indicator switch
13. Head light switch
14. Control lights
a. Oil pression
b. Neutral
c. Electrical charging
d. Front light (high beam)
e. Indicator
15. Brake light switch (front)
16. Connection
17. Horn
18. Engine kill
19. Starter switch
20. Connection
21. Security switch on clutch lever (optional)
22. Connection
23. Oil pression sensor
24. Neutral sensor
25. Connection
26. Starter relay
27. Indicator relay
28. Ignition coil
29. Spark plugs
30. Brake light switch (rear)
31. Connection
32. Fuse box
33. Connection
34. Connection
35. Connection
36. Ignition pickup
37. Ignition
38. Connection
39. Battery
40. Starter
41. Alternator
42. Voltage regulator
43. Rectifier
44. Rear right indicator
45. Rear Light
a. Brake light
b. Rear light
46. Rear left indicator
47. Connection
The G/S and GS web pages: http://www.micapeak.com/bmw/gs/
html-Document, Jean Moxhet,Belgium - 24.07.98
no reproducing in any form w/o permission of the author
2. Headlight box
4. Front light
a. High beam
b. Low beam
c. Parking light
5. Instrument light
7. Key switch
9. Connection
10. Connection
11. Horn switch
14. Control lights
a. Oil pression
b. Neutral
e. Indicator
16. Connection
17. Horn
18. Engine kill
19. Starter switch
20. Connection
22. Connection
24. Neutral sensor
25. Connection
26. Starter relay
27. Indicator relay
28. Ignition coil
29. Spark plugs
31. Connection
32. Fuse box
33. Connection
34. Connection
35. Connection
36. Ignition pickup
37. Ignition
38. Connection
39. Battery
40. Starter
41. Alternator
43. Rectifier
45. Rear Light
a. Brake light
b. Rear light
47. Connection
ckoaca
» voyants de TdB
» Voyants R 60/2
» voyants compteur capricieux
» [75/6] tous les voyants éteints.
» (RESOLU) ... Voyants ne fonctionnent plus.
» Voyants R 60/2
