MOMBAERTS RACE, BOITE DE VITESSE DÉFECTUEUSE ….
+10
bib
Lolo49
Gandalf2
kos11-12
14 participants
Page 2 sur 3
Page 2 sur 3 • 1, 2, 3
Re: MOMBAERTS RACE, BOITE DE VITESSE DÉFECTUEUSE ….
Et voila, attention au interprétations ....pour ceux qui ne sont pas familier avec le vocabulaire technique Anglais , je tient à préciser que c'est l’écrit original et non modifier à part le nom de cette personne, j'ai pas demander son autorisation pour le publier....pour l'instant...Flatosaure a écrit:Je pense que ce serait intéressant de le retranscrire ici, même en anglais.
Hi Konstantin I have finally found the time to look at your gearbox. so here
are the results , the nova layshaft and all the gears on it are perfect ,and
the same goes for the input shaft. But the output shaft is not good,there is
some damage on the taper where the drive flange is fitted, it looks like at
some point the flange has spun on the shaft. First gear on the output shaft
is damaged and the same goes for second gear and forth gear. first gear is
fitted the correct way round, but there are two thrust washers fitted to
either side of fourth gear which should not be there and they stop the
engagement of first on one side and second on the other. at some point first
gear has been on the wrong way round you can see the marks on it. the
fitting of the thrust washers to forth gear have caused the selector fork
which engages with forth to be burned. Also there was a baffle plate missing
under the layshaft which put the layshaft at the wrong height in the box and
bent the 3rd to 4th selector fork and no shims on the layshaft at all, the
3rd to 4th selector fork has also damaged the selector cam before it finally
gave up and bent. I think the nova gears are about £100 each so you need
three you could also do with a shaft approx £130. two selector forks and a
selector cam plus gasket and seals. I would say the approx cost to put it
right would be £600- £700. the cost for stripping and this report is £78.00
plus vat which is £93.60. regards R....
kos11-12
Ca ne change rien. Ils ont donc agit en tant que particuliers, même si c'est sous le couvert de leur société ayant pignon sur rue. Le résultat final est le même. Je me répète: il n'y a pas de facture lorsqu'une transaction portant sur des pièces d'occasion se passent entre particuliers. Si c'était la société Monbaertsrace qui t'avait vendue cette boîte d'occasion, tu aurais eu obligatoirement une facture. Et comme tu l'as écrit:"En d'autre terme je me suis bien fait avoir, et j'ai fait trop confiance, j'aurais due demander la facture avant d'effectuer le payement, et pas de facture pas de payement ."kos11-12 a écrit:J'ai environs 50 emails de Alain Mombaerts .....et 4 ou 5 de Renaud .....Dom a écrit:Bin pour moi c'est clair, ce n'est pas la société Monbaertsrace qui t'a vendu cette boîte; mais le fils, vu qu'il t'a demandé le règlement sur son compte perso. Et donc, voilà pourquoi tu n'as pas eu de facture; car que je sache, il n'y a pas de facture lorsqu'une transaction portant sur des pièces d'occasion se passent entre particuliers.kos11-12 a écrit:
oui sauf qu'il me demande par mail de le régler sur son compte perso par mail, et qu'il est différent de celui de son compte pro .....
Maintenant, il existe des recours pour des transactions litigieuses entre particuliers.
je pense qu'une présentation plus avancé s'impose, désolé si c'est long,
J'habite en Angleterre depuis 1995, depuis peut entre Londres et Cannes, je suis tailleur pour homme de profession.
je possède 2 Ducati mono (450 et 350 un troisième 350cc desmo restauré et vendue à un Austarlien) , 1 BMW d'endurance 1040 de 76, et un autre flat... un six cylindre, une 911, que j'entretient moi même,
une des Ducati, la 350 cc de 1965, est une moto de competition avec laquelle je coure depuis 1999 avec les 2 clubs les plus compétitif d'Angleterre le CRMC et IHRO et aussi le CRMB Belge au TT de Chimay et Gedinne,
tous mes véhicules sont dans un état magnifique , restauré comme a neuf....
dommage que je ne puisse pas poster de photos de la BMW, en tout cas pour ce qui on une copie du hors serie ; SPEED , CAFE RACER de l'année dernière il y a 3/4 page sur ma BMW,
avec la BMW on a courue au BOC il y a quelques années et à Spa 2 fois,
tout ça pour dire que j'ai eut a faire à pas mal de super spécialistes et préparateurs,
Konstantin Moraglis
Konstantin Moraglis
kos11-12
Désolé mais, par les mânes de ce bon gros vieux Fénelon, que ce post est donc mal écrit. C'est fascinant. Ha ha.
La plus forte densité de fautes grammaticales au paragraphe carré !
Éblouissant ! Si Gutenberg avait pu avoir la vision de ce machin, il se serait fait plombier-zingueur.
Gandalf2
Quelle autre langue écris-tu aussi bien que le français ?
Je connais un paquet de français qui écrivent leur langue maternelle vachement bien moins que ça... et c'est pas le sujet du débat, excuse-moi.
Si c'est pour moi ... La langue de bois ou celle de veau
Gandalf2
Salut Konstantin,
Ta bécane, elle a fait l'objet d'un post , on a donc des photos :
http://www.flat-twin-bmw.com/t14259-la-bmw-du-hors-serie-speed-de-cafe-racer
Lolo49
Il l'a vu....il est même intervenu sur le dit topicLolo49 a écrit:Salut Konstantin,
Ben oui Gandalf, c'est à toi que je répondais
Je ne suis pas sur que Konstantin soit français d'origine, donc je trouve que se moquer de son écriture n'est pas le sujet du débat.
Je suis amené tous les jours depuis bien des années à parler avec plus ou moins de bonheur dans des langues qui ne sont pas les miennes et en général les gens apprécient plutôt qu'on fasse l'effort de parler leur langue, même avec des fautes.
Je trouve que c'est un travers typiquement français que de s'en moquer, c'est principalement ce qui reste de l'image des français à l'étranger.
Et je le répète; quand on voit le niveau d'orthographe moyen des moins de 30 ans, ça sert à rien de faire les malins.
Konstantin, désolé si tu es français d'origine
il est un peu chiant spé ce post je trouve
edit : je pensais que ça allait encore finir par retomber sur la gueule des blitz et que j'allais encore essayer de les défendre... mais même pas
bib
Oui, hein...
Comme je le disais dans l'édit de mon précédent post, je pense que tout ça, c'est la faute des blitzFlatosaure a écrit:Oui, hein...
sinon, il y a Nono, là http://www.flat-twin-bmw.com/t23190-et-vous-vous-avez-fait-quoi-cet-ete#479594
qui a posté des photos de lui en slip
vachement plus marrant
bib
Oui c'est bien elle , un peu différente maintenant , les pots , Discs , commodo maître cylindre, et en phase de passer de 1040cc à 980 cc,
cette hiver si les affaires vont bien , cadre de chez mon amis Becks, mais c'est pas seulement les sous , c'est le temps pour tout remonter , il vas faloire tout repenser et faire faire 1 réservoir voir un deuxième , chez The Tank Shop en Écosse .....
kos11-12
Flatosaure a écrit:Ben oui Gandalf, c'est à toi que je répondais
Je parle 3 langues couramment , français , Anglais et Grecque, ,
Né en France de parents grecque et vivant en Angleterre ....
kos11-12
bib
Donc si j'ai bien compris, le fils Mombaerts a vendu (cher) une boîte course d'occasion bien mal montée à quelqu'un qui remets en cause cette transaction, à juste titre semble-t'il.
Au vu de l'état des lieux fait par les Anglais, et du refus de Montbaerts de rembourser la boîte, n'y a t'il pas moyen de saisir une juridiction Belge apte à traiter de ce différent ?
A part ça, Flatman, j'ai bien reçu et encaissé ton chèque pour la boîte de ma G/S. Maintenant, faudrait aussi me payer le reste de la bécane.... :
Si tu connaissais le tarif des avocats tu ne dirais pas ça,en plus il faut qu'il soit spécialiste de droit des affaires international.
En France il y a un truc comme la "saisine simplifiée" pour les difficultés entre particuliers ?
salut ,Francesco a écrit:En France il y a un truc comme la "saisine simplifiée" pour les difficultés entre particuliers ?
c'est là, j’espère...
Le Centre Européen des Consommateurs France ;
Le CEC France est un service soutenu par le Ministère de l'Economie et des Finances (DGCCRF) et la Commission européenne. Il appartient à un réseau européen destiné à informer et conseiller les consommateurs sur leurs droits en Europe et à promouvoir la résolution extrajudiciaire de litiges transfrontaliers entre un consommateur et un professionnel établi sur le territoire d’un autre Etat membre de l’Union européenne, l’Islande ou la Norvège.
kos11-12
Le souci est qu'au regard du droit:
- tu n'as rien acheté à un professionnel puisque tu n'as nulle facture.
- tu n'a pas acheté un bien neuf.
- tu as acheté une pièce à usage de compétition qui ne peut prétendre à aucune garantie que ce soit.
Toute procédure est donc perdue d'avance...
salut,jbt a écrit:Le souci est qu'au regard du droit:
je te remercie pour tes remarques, et tes conseils, je te passe certains autre détailles si non on s'en sort plus, (comme par exemple un texte de sa femme qui me dit qu'elle a fait la facture...mais moi je l'ai toujours pas)
le but de mon poste c'est d'avertir tout le monde sur les pratiques de ces commerçants, et par la même occasion de faire attention quand on achète à distance...
d’après d'autre témoignages recueilli en Belgique je ne serais pas le premier ....j’espère être le dernier ....
j’informerais tout le monde sur la suite,
j'attend toujours une réponse honnête, responsable, professionnel et de sur crois courageuse de leurs part ....
kos11-12
J'ai deux copains Roumains qui font rien en ce moment ...
Je ne suis pas super convaincu par tes arguments, jbt.jbt a écrit:Le souci est qu'au regard du droit:
- Même s'il n'a pas de facture, il a quand même la preuve qu'il a acheté un bien et un service à un pro, les deux étant totalement dans le domaine d'activité du pro. Le côté fiscalement furtif de l'affaire n'enlève rien à sa réalité et il n'est sans doute pas en faveur du pro si jamais ça va au tribunal, surtout s'il y a des preuves écrites.
- Pour le fait que ce ne soit pas un bien neuf, je ne vois pas le rapport: il se vend chaque année en Europe des millions de voitures d'occasion, révisées et garanties par des professionnels. Quand tu amènes ta voiture ou ta moto en panne au garage, le garagiste ne peut pas te dire après que tu aies payé la réparation "ah oui, ça marche toujours pas mais je m'en fous, c'est une voiture d'occasion".
Si, il peut dire ça ?
Toi tu le dirais ?
- Pour ton troisième argument, c'est possible, j'ai déjà entendu ça. Mais je dirais aussi que quand un pro qui a le mot "race" dans son nom te vend une boîte révisée par lui et clairement destinée à la course, ça sous-entend quand même un minimum d'obligation de résultat. Pas que la boîte ne casse jamais, on est d'accord, mais pas non plus qu'elle explose en 3mn.
La garantie, la loi et les procédures c'est une chose, après il y a aussi le travail bien fait et la valeur qu'on donne à son propre boulot.
Je comprend ce que tu peux ressentir,je viens moi même de me faire arnaquer sans espoir de récupérer quoi que ce soit,ça fait mal.
Nono,tes potes roumains,s'ils sont pas trop surbookés,tu pourrais leur dire de passer?
Je connais aussi des nigérians désœuvrés Richard, si tu veux...
Ouais mais bon,pour une fois qu'il y a des roms qui ont envie de bosser...
» http://www.mombaerts-race.com
» Est ce que Mombaerts-race existe toujours ???
» Mombaerts (??) PIRATAGE BOITE MAIL
» [R100/7 1983] Remontage de boite de vitesse - Vitesse qui ne passe pas bien
» boite a vitesse qui grince et vitesse qui passe mal
Page 2 sur 3
