Jeux, jouets et Lego : le deuxième à -50% (large sélection)
Moteur 1043 - "perdu" par TNT
Moteur 1043 - "perdu" par TNT Empty Moteur 1043 - "perdu" par TNT
Message  Ras Thurlo Dim 10 Mai 2015 - 23:44
If any of you guys are offered a v.clean looking airhead engine from an employee of TNT let me know.
The engine is easily distinguishable as it has the narrower cylinders of the 1043 HPN pistons and a kick-start gearbox
The whole pallet "disappeared" in transit down from UK to Italy
I don't expect to see it again, but was hoping to make the on-sale more challenging
Ras Thurlo
Ras Thurlo
Moteur 1043 - "perdu" par TNT Empty Re: Moteur 1043 - "perdu" par TNT
Message  jbt Lun 11 Mai 2015 - 8:01
Bad news...
Do you have a serial n° for that engine? Or any specs that would allow to recognize it more easily?
It's a small world.
Message  Ras Thurlo Lun 11 Mai 2015 - 9:08
jbt a écrit:Bad news...
It's a small world.
Yes, its a small world (that's why I am hoping to ruin someone's engine sale)
unfortunately did not take down engine number. However there are not many airhead engines with the shorter 1043 HPN cylinders around, so it would stand out.
I don't think it will be in France, but the market is pan-European so thought it was worth a try....
....otherwise a Moldovan is going to enjoy the torque that the 1043 pistons and a 296 Enduro can would give
Ras Thurlo
Ras Thurlo
Message  jbt Lun 11 Mai 2015 - 9:21
I guess so...
was the engine new, used in appearance?
With clutch, carbs, starter?
Based on /7 or post 84 engine?
Message  Ras Thurlo Lun 11 Mai 2015 - 9:54
engine looked new, full vapour blast
short cylinders (as stated above)
kick-start gearbox
no carbs - this was the only part of the delivery that made it to Italy
Ras Thurlo
Ras Thurlo
Message  jbt Lun 11 Mai 2015 - 10:11
OK. I'll translate for non english speakers;
Ras Thurlo signale donc qu'il s'est fait voler un moteur de BMW lors de son transport entre le Royaume uni et l'Italie via TNT.
Le moteur possède des cylindres courts HPN, un arbre à cames enduro 296, une boite de vitesse à kick. L'ensemble est d'apparence très propre, nettoyé à la vapeur.
Si on vous propose d'acheter une mécanique complète...pensez à lui!
